We’re sorry. We could not find a match for your search.
We suggest you try the following to help find what you're looking for:
  • Check the spelling of your keyword search.
  • Use synonyms for the keyword you typed, for example, try “application” instead of “software.”
  • Start a new search.
Wireless POS Terminals
Oracle MICROS Workstation 3 is our most compact, wireless POS terminal. Purpose-built for harsh, remote environments, Workstation 3 fits in anywhere. From local startups to world-renowned stadiums, Workstation 3 has the speed, power, and versatility to adapt with restaurants as their needs evolve.
Our wireless POS terminal is available for US$1
Skip expensive, upfront investments with our US$1 point-of-sale terminals. Now is the best time to speak with an Oracle product expert about our POS hardware and switch to Simphony, our cloud-based restaurant management platform.
Oracle MICROS Workstation 3 technical specifications
The wireless Workstation 3 combines style, modern design, and durability taking your restaurant technology to the next level. Check out the specs below.
Bright, anti-glare display
A 10.1” anti-glare touchscreen with 10-point simultaneous touch and ambient light sensor that supports 800 Nit brightness, reducing the appearance of fingerprints.
Customer-facing display
A 256 x 64 graphical OLED display faces the customer, showing order details clearly in the brightest of locations.
Magnetic card reader
As an optional enhancement, a fingerprint reader provides a quick and secure authentication method for employees.
Multiple stand options
Workstation 3 touchscreens can be mounted to basic or flexible stands with a wide range of positioning for optimal viewing angle and cable management.
Full-shift battery power
A full-shift 83 Wh battery makes it easy to position the terminal wherever it’s needed. Charging is via a 15V@5.33A (80W), 80~264VAC external power supply.
Heat and moisture resistant
Workstation 3 is built to withstand temperatures from -10°C to 60°C as well as from water, heat, and smoke damage with a best-in-class IP55 rating.
Fanless cooling
Fanless cooling systems reduce the risk of mechanical failure while protecting against the circulation of humidity, dust, and grease throughout the system.
Shock and vibration resistance
Fanless systems also feature improved shock and vibration resistance, reduced power consumption, and increased overall reliability.
Operating systems
Workstation 3 runs with speed and ease on your choice of Oracle Linux for MICROS and Microsoft Windows 10 IoT Enterprise (64-bit) operating systems.
Processors
Built on the Intel Atom x5-E3930 Processor @ 1.30 GHz, 2C/2T, 2M cache processors for IoT applications, designed for embedded use, with a 15-year lifespan.
Memory and storage
Comes standard with 4GB DDR3L @ 1600 MHz and an 8GB maximum capacity. Storage capacity comes standard with 64GB eMMC v5.0, 400MB/sec MAX, non-removable.
I/O ports
Primary I/O ports include 1 1x IDN (RS422/RS232) – RJ45 port, 2 8-pin miniDIN (12V) Series 2 Cash Drawer connectors, 1 RS232 – RJ45 port, 2 USB 2.0 ports, 2 USB ports, 1 USB 15V/5V, and 1 GbE (10/100/1G) ethernet port.
MICROS Workstation 3 customer success stories
Outback Steakhouse runs Workstation 3 POS terminals
The Oracle MICROS Workstation 3 tablet is part of Outback Steakhouse's cloud-based technology stack powered by Simphony, Oracle's all-in-one restaurant management platform.
Europa Park delivers great guest experiences with Oracle MICROS hardware
See how Oracle MICROS Simphony Cloud, POS hardware, and self-service kiosks are improving speed of service.
Indian Wells serves tennis fans fast with Oracle MICROS POS terminals
Learn how Oracle’s restaurant technology is helping Indian Wells ace their customer experience.
Queensland Country Bank Stadium uses Oracle MICROS Wireless POS to boost concession sales
Learn how Queensland Country Bank Stadium’s deployment of more than 160 Oracle MICROS Workstations takes them to the next level of speedy service.
Portable, powerful, and wireless POS
Oracle MICROS Workstation 3 features a modern, yet durable, design that runs with speed and ease—without needing a wired power source. Accept payments, manage customer orders, and keep your front of house running smoothly and wirelessly from a single screen.
Small footprint. Big impact.
Workstation 3 offers full-service restaurant capabilities in a sleek, portable design that allows multiple workstations to process queues faster.
Ideal for remote locations, such as poolside bars, food trucks, stadiums, and more.
Integrated LAN connectivity, magnetic stripe reader, and customer-facing display give you everything you need.
Virtually indestructible
Our wireless POS terminal is designed for speed, durability, and portability.
  • Fanless system eliminates the circulation of dust, generates less heat, and requires less power
  • Improved shock and vibration resistance prevent premature damage and reduce the likelihood of mechanical failure
Bright touchscreen display
Our 10-inch HD touchscreen with adjustable stand is recognizable in thousands of restaurants.
  • Improved visibility and ease of use for customers and staff when working in variable environments
  • Anti-glare display minimizes on-screen glare common with outdoor dining events or mobile restaurant operations
Optimised for contactless pay
Full payment processing capabilities that allow customers to choose how they want to pay.
  • Compatible with multiple contactless payment options, such as card readers, mobile wallets, Apple Pay, and more
  • Connect with third-party peripherals via wired connections, Wi-Fi, and Bluetooth
All our MICROS Workstations run on Simphony
Simphony point of sale from Oracle is an all-in-one restaurant management system for restaurants of any size. Simphony acts as your integrated, cloud-based platform for front-of-house, kitchen, and back-office operations. Real-time analytics and reporting provide the insights needed to spot and source new revenue opportunities.
Get an Oracle MICROS Workstation 3 for US$1
Oracle is the restaurant POS provider of choice for those looking to expand operations and improve customers’ experiences. Connect with one of our product experts today and let us help you design a hardware solution tailored to you. Ask about how you can make the switch to a Workstation 3 for just US$1.
