Meet the Oracle Workstation 8
The Oracle Workstation 8 is the latest addition to the Oracle POS hardware solution family. Featuring a slim, 14-inch touchscreen display and warm platinum finish, the Workstation 8 fuses a modern, sophisticated look with the reliability and dependability Oracle customers trust.
Oracle Workstation 8 technical specifications
With its modular design, restaurant operators can select the solution that best suits their brand standards for staff and customer experience. The low-profile configuration is designed to remove the barrier between staff and guest to facilitate direct eye contact and engagement. The upright configuration includes a vertical stand with a peripheral expansion module and weighted base, which conceals cables exceptionally well, creating a clean, uncluttered setup.
Workstation 8 terminals deliver a sophisticated solution that is built to last with the following features:
Customer display
The Workstation 8 features a suite of optional 7-inch customer displays for a seamless customer experience at the counter.
Modular design
The Oracle Workstation 8 Series features connectivity in the head unit for use on its own, or you can leverage the Peripheral Expansion Module for expanded connectivity.
Powerful processor
The Workstation 8 Series features a quad-core, high performance embedded Intel CPU.
Preassembled systems
Shorten setup time with our preassembled systems. Everything you need for the Workstation setup is included in one package that reduces packaging materials and waste.
Storage
The Workstation 8 Series is available with either 128 GB SSD or 256 GB SSD storage.
Fanless cooling
Fanless cooling allows the system to run quietly and eliminates the circulation of dust, pathogens, grease, and humidity throughout the system, reducing the risk of overheating.
IP-rated
Our systems are IP-rated to withstand splashes and spills, making the Workstation 8 a great choice for restaurant environments.
Operating systems
The Workstation 8 Series runs with speed and ease on your choice of Oracle Linux for Restaurants or Windows 10 IoT Enterprise operating systems.
Display specifications
The 14-inch widescreen, FHD display features on-cell touch technology with antiglare coating.
Heat and moisture resistance
Built to withstand temperatures ranging from 0°C to 50°C.
Upright design
The vertical stands expertly hide cabling for a clean countertop aesthetic. Available as both fixed angle and adjustable tilt.
Thoughtful, modular design
Workstation 8 Series marries form with function, featuring multiple configuration options to accommodate varying customer requirements.
Low profile
The slim, compact design of the low-profile stand allows for a more organic way of transacting, enabling staff to increase engagement with customers. Available with or without the integrated 7-inch customer display.
Upright design
The vertical stand with a fixed angle is the perfect solution for locations requiring a traditional, upright installation. The weighted base not only provides stability for the vertical stand but also encloses the Peripheral Expansion Module and expertly conceals cabling for a clean aesthetic.
The vertical stand with adjustable tilt provides greater flexibility, allowing users to adjust the display angle. This is an optimal solution for businesses with nonstandard counter heights or any environment with variable lighting.
The vertical stand with adjustable tilt also features flip-to-self-service functionality, allowing the associate to flip the display from associate-facing POS to self-service mode.
Additional restaurant POS hardware
Workstation 6 Series
The Workstation 6 is a purpose-built system that features an expansive 15.6-inch touch display and extensive peripheral connectivity.
Compact Workstation 3 Series
This durable 10-inch portable POS is built to last and features robust specs, making it the ideal solution for semi-outdoor or outdoor environments.
All POS hardware
Our POS terminals and mobile devices are designed to withstand spills, harsh weather, constant use, and security threats. Powered by Simphony POS software from Oracle, our POS hardware helps restaurants elevate the speed and quality of their service, in-house and online.
