Mobile POS for Restaurants
Oracle MICROS Tablet 700 Series is a mobile POS solution designed to hold up to heat, spills, and drops while managing every swipe, tap, and scan. Customers can choose their preferred contactless payment option, and the tablet will handle the rest. Staff can send orders to the kitchen, monitor timings, and update inventory in real time. Our handheld tablets make restaurant management simpler for all kinds of dining experiences, including indoor dining and curbside.
Learn why restaurant technology that incorporates an omnichannel digital transaction platform is imperative.
Outback Steakhouse relies on Oracle mobile POS tablets
Oracle mobile POS is part of a cloud-based tech stack powered by Simphony, Oracle's all-in-one restaurant management platform.
“I can't emphasize enough how much Oracle Simphony has helped our business. The system is completely scalable, so now our business is efficient, and our staff can give quality time to our dine-in customers.”
Mike Palmer Operating Partner, Outback Steakhouse Australia.
The best-in-class mobile POS tablet is available for $1, no strings attached
  • Our $1 POS tablets help restaurants skip the expensive, upfront investment in POS hardware. Now is the best time to speak with an Oracle product expert about taking advantage of our $1 POS hardware offer and switching to Simphony, our cloud-based tablet POS software.
    Watch the video (0:43)
Oracle’s mobile POS tablets
Oracle Tablets help staff manage tables, curbside pickups, inventory, and other operations from anywhere on the property using Simphony, our secure, cloud-based POS software.
  • Accelerate service and avoid strain on the kitchen with a single integrated system that manages your front and back of house operations
  • Access real-time reporting and analytics to inform business decisions that reduce costs and improve service
Equipped with a long-lasting battery, you can ensure your staff is prepared to handle any service. With multiple charging options, your staff can stop worrying about the tech and spend more time with guests.
  • Reduce charging time between services with an 8-hour hot-swappable battery
  • Other accessories available: extended battery, carrying pouch, bay tablet gang charger, extended battery charger, desktop charging cradle, and more
Bump it. Spill on it. Drop it. The Oracle Tablet can handle the chaos of your kitchen. Our modern, portable tablets are designed to match any restaurant decor while standing up to the rigors of dinner service.
  • Surrounded by standoffs and corner bumpers to prevent damage from face falls and impact to corners and edges
  • Resistant to all the heat, spills, and grease that inconvenience service and staff
  • Equipped with stable offline mode so that even a bad Wi-Fi connection doesn't slow you down
Process orders and payments anywhere in your restaurant. Accept all forms of contactless payments to create a single source of truth for all of your orders, receipts, and payment information.
  • Equipped with integrated Wi-Fi, Bluetooth connectivity, magnetic stripe reader, and optional barcode scanner
  • Runs securely on Microsoft Windows 10
The Oracle Tablet is designed with form and function in mind. Our lightweight, portable design makes it ideal for both indoor and outdoor dining. And our catalog of POS accessories allows for easy customization based on the needs of your staff.
  • Durable, lightweight, and sized to fit inside an apron pocket
  • Tether mounts and corner hardware support shoulder and hand straps
  • Connects to a rich variety of Wi-Fi- and Bluetooth-supported peripherals
Simphony Point of Sale from Oracle is an all-in-one restaurant management system for restaurants of any size. Simphony acts as your point of truth for front-of-house, kitchen, and back-office operations from a single, simple, cloud-based platform. And real-time analytics and reporting provide the insights needed to spot and source new revenue opportunities. Stay one step ahead with Simphony.
  • Online ordering, contactless pickup, and delivery
  • On-premises table management and payment processing
  • Kitchen display system integration
  • Reporting and analytics
  • Menu management
  • Inventory management
  • Employee management and scheduling
  • Gift and loyalty program management
  • POS integrations with 85+ approved vendors and a flexible API
Oracle tablet technical specifications
With integrated Wi-Fi and Bluetooth connectivity, embedded CPU, and long lifecycle OS, the Oracle MICROS Tablet 722P improves the guest experience by increasing efficiency, improving productivity, and streamlining operations. Check out the latest specs for Tablet 722P below.
  • 7-inch LED touchscreen display
    LED-backlit, optically bonded screen with capacitive touch for greater durability, improved viewing and touch experiences, and maximum dust and moisture protection.
  • High-durability enclosure
    Hard casing uses strong ABS + PC plastics and rubber corner bumpers to help prevent damage from drops and bumps.
  • Battery and charging
    Hot-swappable, 8-hour rechargeable Li-ion polymer battery included to avoid downtime. Additional charging accessories include a 4-bay battery charger, 4-bay tablet charger, desktop charger, or standalone power supply.
  • Heat and moisture resistance
    Tablet 722P can operate in temperatures between 0 °C and 40 °C for decreased likelihood of component failure due to overheating, and humidity tolerance range of % – 90% non-condensing for decreased likelihood of component corrosion.
  • Tech specs
    Tablet 722P runs on Windows® enterprise operating system, embedded Intel® Quad Core CPU, and 4GB memory/128GB SSD. Connectivity options include Wi-Fi 802.11a/b/g/n/ac WLAN and Bluetooth 4.0 LE.
  • Available features
    Both entry and full-featured models include a triple track magnetic stripe reader, with the full-featured model also featuring an integrated barcode/QR code scanner, 5 mega-pixel rear camera, and NFC/RFID reader.
Get started with Oracle Restaurants
Speak to an expert
Engage one of our solution experts today.
See Simphony live
Get a personalized demo of Simphony POS.
Stay connected
Expand your network and connect with peers.
