In this article, you'll learn how to set up and edit your Schedule of Values in Textura.
Next, click Add New Line. Enter the following information:
Add lines as needed. Once you save, the lines in your budget will automatically sort based on the phase code.
Cut and paste your Schedule of Values into the example spreadsheet and save the file. In Textura, delete the single-line entry. Browse to select your saved Excel file and click Upload.
Click Save Changes.
You may have to edit your Schedule of Values again if the General Contractor makes a change to the value of your contract.
If so, you'll receive an email informing you of the General Contractor's Change Order and a link to edit your budget.
A task notification is also displayed on your Project Home page. Click the link in the email or the task on the Project Home page.
The page displays the number of Change Orders you have to allocate and the Change Order you are currently allocating with dollar amounts.
The Change Order causes the working subtotals and totals rows at the bottom of the table to be out of agreement.
Allocate the Change Order to one or more of the existing rows in your Schedule of Values, or add a new line to allocate the entire Change Order.
If you add a new line, type:
You must allocate the exact amount of the Change Order.
Allocating a Change Order does not affect the totals in the Schedule of Values Amount column.
However, the Change Order is reflected in the Allocate, Net Change By Change Order, Contract Sum to Date, and Balance to Complete columns.
Click Save Changes.
You can repeat the process until all Change Orders are allocated.
The page displays a summary of the Change Orders on the contract, as well as a list of the individual Change Orders that can be filtered on multiple columns.
