Oracle’s SPARC T8 and M8 servers are the most advanced systems for enterprise computing, with unique capabilities that provide up to 2x faster performance for databases and Java applications compared with competitors’ systems as well as end-to end security features for maximum protection. Using breakthrough second-generation Software in Silicon technology and coengineering of Oracle hardware and software, Oracle’s family of SPARC servers is ideal for Java software, databases, and enterprise applications, and the servers’ rich feature set provides the foundation for building the best and most secure mission-critical cloud infrastructure.
The SPARC T8-1 server offers a single processor, a maximum of 1TB of memory, eight 2.5” hot-swappable HDD/SSD drives with NVMe support and six PCIe 3.0 slots.
The intent of the power calculator is to provide guidance for estimating the electrical and heat loads for typical operating conditions. It should not be used to calculate power or HVAC requirements. Instead, please use the appropriate installation guide to allow for proper allowances.
Notices and Disclaimers
  • Note: JavaScript must be enabled to view this section of the website.
  • Configure your SPARC T8-1 server system and calculate your server total power consumption!
SPARC T8-1 Server Power Calculator
Item Quantity Notes
Processor
Select Processor Type
Number of CPUs
Select Number of CPUs
Memory
(64GB DIMM)
Select number of DIMMS
Memory
(32GB DIMM)
Memory
(16GB DIMM)
Hard Disk Drives
Select number of Hard Disk Drives
(Min 0, Max 8 Total per System)
Solid-State Drives (2.5-inch)
Select number of Solid-State Drives
(Min 0, Max 8)
NVMe Drives
Select number of NVMe Drives
(Min 0, Max 4 drives)
NVMe Switch Card
Select number of NVMe Switch Cards, required when NVMe Drives are included
(Min 0, Max 1, the card occupies one PCIe slot)
Oracle Flash Accelerator F640 PCIe Card
Select number of F640 PCIe Cards
(Min 0, Max 6)
PCIe Cards
Select number of PCI-Express Cards
(Min 0, Max 6, Max 5 if using NVMe switch card)
Indicate Workload (%):
Select Workload range
(1% - 100%)
Sample Results
Item
Active Idle Power
Sample Power
Total Power of System   (Watts)
(estimated)
(estimated)
Total Power of System   (BTU/HR)
(estimated)
(estimated)
You MUST allow electrical and cooling headroom for unforeseen circumstances, component upgrades, and increased computational loads. Please allow for worst-case power conditions. Actual power consumption will vary from the sample workload used in the power calculator. These include, but are not limited to, the factors below. Each of these factors may cause significant differences in power consumption:
  • Actual workload and its fluctuations
  • Ambient temperature
  • Cooling patterns
  • Excessive inlet temperature
  • Humidity
  • Operating systems features
  • Power management settings
The "Max Operating Power (35°C)" results shown represent the power consumption measurements with CPUs at 100% utilization and with DE3 Disk Trays at 35C° ambient temperature. The "Typical Power" results represent power consumption measurements taken when system booted and stabilized, yet running at minimal utilization. Sample results shown are representative of measurements taken with room temperatures below 25°C. System power can vary depending upon hardware/software configurations and environmental conditions. For precise results, actual measurements based upon the exact hardware/software/environmental conditions are recommended.
Legal Notice: This calculator is subject to change without notice and is provided "as is" without warranty of any kind, express or implied. Oracle does not make any representations regarding the use, validity, accuracy or reliability of the tool. The entire risk arising out of the use of this tool remains solely with the customer. In no event shall Oracle be liable for any direct, consequential, incidental, special, punitive or other damages, even if Oracle is negligent or has been advised of the possibility of such damages, arising from use of the tool or the information provided herein.
