We’re sorry. We could not find a match for your search.
We suggest you try the following to help find what you’re looking for:
  • Check the spelling of your keyword search.
  • Use synonyms for the keyword you typed, for example, try "application" instead of "software."
  • Start a new search.
Cloud Account Sign in to Cloud
Oracle Account
Oracle's M7 servers are the world’s most advanced systems for enterprise workloads, with unique capabilities for information security, database and Java acceleration. Unique Software in Silicon technology in Oracle's new SPARC processor provides full speed encryption, plus detection and prevention of attacks to critical data in memory. It also enables real time analytics to be performed on OLTP databases by accelerating Oracle Database 12c In-Memory queries. The combination of the world’s highest performance with breakthrough Software in Silicon features is the foundation to building the best and most secure mission critical clouds.
The SPARC M7-8 server offers up to eight SPARC M7 processors, scales up to 4 TB of memory and has up to 24 PCIe 3.0 (x16) slots. It offers one or two physical domains. When ordered with two physical domains, the server offers up to 4 processors per domain. When ordered with a single physical domain with up to 8 processors, the SPARC M7-8 server allows for high scalability in a large memory footprint.
The intent of the power calculator is to provide guidance for estimating the electrical and heat loads for typical operating conditions. It should not be used to calculate power or HVAC requirements. Instead, please use the appropriate installation guide to allow for proper allowances.
Notices and Disclaimers
  • Note: JavaScript must be enabled to view this section of the website.
  • Configure your SPARC M7-8 server system and calculate your server total power consumption!
SPARC M7-8 Server Power Calculator
Item Quantity Notes
Processor
Select Processor Type
Number of CPUs
Select Number of CPUs
Each CPU is on a CMIOU board with 16 memory slots and 3 PCIe 3.0 slots.
Memory Size
16 x 64GB DIMMs
Select number of CMIOU boards configured with 16 x 64GB DIMMs
Memory Size
8 x 64GB DIMMs
Select number of CMIOU boards configured with 8 x 64GB DIMMs
Memory Size
16 x 32GB DIMMs
Select number of CMIOU boards configured with 16 x 32GB DIMMs
Memory Size
8 x 32GB DIMMs
Select number of CMIOU boards configured with 8 x 32GB DIMMs
Memory Size
16 x 16GB DIMMs
Select number of CMIOU boards configured with 16 x 16GB DIMMs
Memory Size
8 x 16GB DIMMs
Select number of CMIOU boards configured with 8 x 16GB DIMMs
PCIe Cards
Select number of PCIe Cards
(Min 0, Max 3 per CPU)
Indicate Workload (%):
Select Workload range
(1% - 100%)
Sample Results
Item
Active Idle Power
Sample Power
Total Power of System   (Watts)
(estimated)
(estimated)
Total Power of System   (BTU/HR)
(estimated)
(estimated)
You MUST allow electrical and cooling headroom for unforeseen circumstances, component upgrades, and increased computational loads. Please allow for worst-case power conditions. Actual power consumption will vary from the sample workload used in the power calculator. These include, but are not limited to, the factors below. Each of these factors may cause significant differences in power consumption:
  • Actual workload and its fluctuations
  • Ambient temperature
  • Cooling patterns
  • Excessive inlet temperature
  • Humidity
  • Operating systems features
  • Power management settings
The "Max Operating Power (35°C)" results shown represent the power consumption measurements with CPUs at 100% utilization and with DE3 Disk Trays at 35C° ambient temperature. The "Typical Power" results represent power consumption measurements taken when system booted and stabilized, yet running at minimal utilization. Sample results shown are representative of measurements taken with room temperatures below 25°C. System power can vary depending upon hardware/software configurations and environmental conditions. For precise results, actual measurements based upon the exact hardware/software/environmental conditions are recommended.
Legal Notice: This calculator is subject to change without notice and is provided "as is" without warranty of any kind, express or implied. Oracle does not make any representations regarding the use, validity, accuracy or reliability of the tool. The entire risk arising out of the use of this tool remains solely with the customer. In no event shall Oracle be liable for any direct, consequential, incidental, special, punitive or other damages, even if Oracle is negligent or has been advised of the possibility of such damages, arising from use of the tool or the information provided herein.
