Your search did not match any results.
We suggest you try the following to help find what you’re looking for:
Oracle's servers based on the SPARC M7 processor are the first to support the revolutionary Software in Silicon technology which enables the real-time enterprise through unprecedented levels of security, efficiency and value. The SPARC M7-based servers are the ideal platforms for databases, Java and application deployments. The rich feature set offers the best value for cloud infrastructure and business-critical enterprise applications.
The SPARC T7-4 server offers four processors, a maximum of 4TB of memory, eight 2.5” hot-swappable HDD/SSD drives with NVMe support and sixteen PCIe 3.0 slots.
The intent of the power calculator is to provide guidance for estimating the electrical and heat loads for typical operating conditions. It should not be used to calculate power or HVAC requirements. Instead, please use the appropriate installation guide to allow for proper allowances.
